Fusion Support
Aligning sketches to center point
7 REPLIES 7
Message 1 of 8
vegard.midtboen3DK2Q
810 Views, 7 Replies
I have just gone from SolidWorks to Fusion 360, and I'm really missing a important feature. How can I align a sketch to a center line. In the example below, I want to align the circle to the center of the top line. I want to do this without wasting time on creating construction lines.
7 REPLIES 7
Message 2 of 8
Constrain > Coincident
Select circle Centre Point,
hold down Shift Key,
select Midpoint of the line.
Might help....
Message 3 of 8
Hi @davebYYPCU
Thanks for the reply.
When I try this, the circle connects to the center of the line. I just want to align with the center and place the circle a distance below the line.
Message 4 of 8
Sorry, Constrain > Vertical
same selection routine.
Might help....
Message 5 of 8
in reply to: vegard.midtboen3DK2Q
Easy.
Message 6 of 8
davebYYPCU
Create > Point, is not required in my workflow.
Might help...
Message 7 of 8
Perfect, this is just what I was after!
Thanks to both of you!
Message 8 of 8
try this
günther
