Sheetmetal move should enforce rules
TravisJoe
TravisJoe
I tried the move command on a sheetmetal face and found that it extruded the outer face instead of moving the flange. I somewhat expected this to happen but I feel goes against how sheetmetal should work in fusion.
My thoughts are that move should enforce the sheetmetal design rules and cause the flange with correct thickness to move. I can understand when using extrude that you might cause sheetmetal part to not be "proper", but it seems move should logically move the flange and maintain proper thickness. In the context of sheetmetal I believe Push/Pull I believe should also act more like move over extrude.
promm
@TravisJoe,
Thank you for the feedback, I am looking into what are the possibilities and limitations of this workflow.
Cheers,
Mike Prom
