How to switch from a branch back to master branch
I'm in a current design branch, but I want to get back to the master and abandon that branch, but maybe come back to it later.
Is there a way to switch back to the master part?
Best,
Matt
jan_priban
Hi Matt,
yes, you can switch back to master branch and let your branch as it is. Branch is like "project copy". Changes you made on part while you worked on branch will not be applied on part on master branch. (To bring/transfer changes you have made on part on branch to part on master, you need to use branch command MERGE.)
See HELP link how to switch among branches: http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-67792291-4519-4D87-BAC1-0135B863CD4E
Regards
Jan Priban
Fusion 360 team
