Browser: Bug Slot
Browser: Bug Slot
Message 1 of 9
Browser: Bug Slot
I found this problem
Replies (8)
Message 2 of 9
HughesTooling
Is it the same as this one.
https://forums.autodesk.com/t5/preview-functionality/fusion-ib-arc-slot-bugs/td-p/6916108
How many more guesses do I get?Smiley Very Happy
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 9
HughesTooling
Seems to be a problem selecting any point including the origin.
Mark
Mark Hughes
Message 4 of 9
JasonBrynfordJones
Hi Guys
Good find, thanks for spotting that.
I have added the issue FZC-1735 Slot does not work using another slot as a reference
It has been prioritized, so hopefully we will have a fix out soon.
Jason
Message 5 of 9
HughesTooling
@JasonBrynfordJones wrote:
Hi Guys
Jason
HI Jason
The bug is slot doesn't work if the start is a point, any point not just another slot. As a quick test try selecting the origin point.
Mark
Edit. Just tried again and I can start a slot from the origin but it does fail if you select an endpoint of a line or arc.
Mark Hughes
Message 6 of 9
JasonBrynfordJones
Ah yes, sorry about that.
I have updated the issue "Slot does not work when starting on a vertex"
Thanks again
Jason
Message 7 of 9
Sketch.pngi'am getting this kind of warning when i constructing a plane(parallel).please help ,i don't know what to do.
Message 8 of 9
JasonBrynfordJones
Hi
I will ask around here if someone knows, but if this is a general Fusion issue, you would probably be better to post in the general Fusion forum
https://forums.autodesk.com/t5/design-validate-document/bd-p/124
This forum is related to workflows that are currently in Preview, and this post relates to a Fusion in the Browser bug.
All the best
Jason
Message 9 of 9
HughesTooling
Normally that happens if you have the construction folder hidden or the component you're working in is hidden, check all the lightbulbs are on. Can you get a screenshot of the browser as well?
Mark
Mark Hughes
