Z height incorrect in gcode?
Simulation looks good in F360, previews look good in two different downloaders (SourceRabbit and cncjs) but when I run the file it runs about 1" above the stock? Machine and Work both at zero when starting. I set zero at center of material (4" dimension) on top edge, left side. Something in the code? - see attached.
I've tried regenerating the code a couple times - no change. I've run other files and they are fine.
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
Can you share the Fusion file? It looks like the origin is set to the bottom when I plot your code. Does this correspond to where you're zeroing at the machine?
Cheers,
Karina
You nailed it - thanks!
