Troubles with probe inspection
I am having some difficulties getting my HAAS VF-6 (Pre-NGC) CNC mill to run my probe inspection toolpath without getting an alarm. I have tried just about every setting alternative that I can think of and was wondering if anyone else has had similar problems or can just lend me some advice. I am using the correct post (pre-ngc) from the Autodesk library and the baud rate, parity, stop bits and data bits are all set to the same settings that fusion recommended on their probe inspection tutorial. I have no problem sending the program the machine via RS-232 through the COM7 port but can not run the program without triggering an alarm. The alarm is saying RS-232 Buffer Overflow. I will attach some pictures and snap shots I took to show what the set up looks like. Also, I am using the terminal in Putty to receive from the CNC. Any help is greatly appreciated.
Best Regards,
-Billy Weaver
Billy Wl;
