- Mute
- Permalink
- Report
I've created a 2D design intended to be cut using a plasma cutter. I've started the design from scratch three times now, and when I got to cut the 2D profile, a section of the drawing just will not process. I get the following notice:
Feature flags: setup-sheet-viewer
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to /var/folders/67/cy4px8fx70s4mszy_7_lsch80000gn/T/Neutron/Fusion360CAM/1/operation3.ironjob
Debug: Writing jobfile to /var/folders/67/cy4px8fx70s4mszy_7_lsch80000gn/T/Neutron/Fusion360CAM/1/operation3.hsm-job
Debug: Using CAM kernel from: /Users/Mamed/Library/Application Support/Autodesk/webdeploy/production/cdedd4b05efae2d277df7be3d315d4ccce03a01d/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/camkernel
Warning: One or more passes were discarded due to linking constraints.
Debug: Autodesk dcamcomponents 1.95.0 pm12672
Autodesk CAM Kernel 3.27.2 (a5be7baa) STABLE a5be7baa53fc5f4d6083bae464035d2fda5f14c6 2021/07/13 06:00
Debug: Total processing time: 4692 ms
Debug: Total elapsed time: 5512 ms
Generation completed with 1 warning(s) in 5.5s.
The section of the design is large enough to have a lead-in cut (other parts of the drawing are smaller and no problems there) and it's always the same part of the design that won't create a tool path.
The Design:
The tool path generated:
Could someone lead me to what might be going on here? Thank you!
