Tool Library Coolant failure
v_tsybulnyk
v_tsybulnyk
After last Update i have now very strange point that my tool library works not good.
Coolant is always be reset to FLOOD even when i change it.
Have somebody also this problem ?
seth.madore
Yes, this is a known bug with a few active threads in recent days. The development team is working on a fix, no ETA on this.
Seth Madore
gtippingPAJL5
WOW!
I thought I was losing my freaking mind!!  Yes, mine is messed up too.  Glad to know I am not totally bonkers.
roughtrussell
Thank you. I swear I searched for it but I must have been doing it wrong. You are right, that is the exact same issue.
Thanks again 👍
seth.madore
@v_tsybulnyk
@roughtrussell
@gtippingPAJL5
An update went live last night that should cure these issues. Do let us know if you are still encountering issues, and thank you for your patience!
Seth Madore
iporter6
Hi Seth
This problem is still present for me.  I guess I only noticed it because I wanted to use a tool without coolant.  Could you check to see if it happens for you?
Ivan
PeterBelfanti
I am getting coolant on, when both my tool libary and the operation call for NO coolant.
