Taper Face Part
Taper Face Part
turbobug64
Message 1 of 9
Taper Face Part
turbobug64
I can't seem to get this part to CAM up at all. It is struggling with this simple shape.
Any ideas how to make this?
Replies (8)
Message 2 of 9
akash.kamoolkar
@turbobug64 Can you attach a sample file so I can take a look?
Akash Kamoolkar
Software Development Manager
Message 3 of 9
turbobug64
I have an IPT since I am working on it in Inventor at the moment.
Message 4 of 9
turbobug64
I was going to drill down the center to depth and then use my small boring bar to face it. It wont seem to let me drill without a hole in the center? Or if there is a better way to do it I can do it that way?
Message 5 of 9
DarthBane55
Inventor is 3 years behind Fusion in CAM, specially for lathes, so this would very possibly work in Fusion but not in Inventor (I know, I use Inventor mainly as well, but you can't really post an Inventor question here for CAM anymore, the distance between the 2 softwares has grown a lot in the past 3 years).  I recommend you post this in the Inventor CAM forum, and hope for the best...
Message 6 of 9
turbobug64
That is cool you guys can CAM it up in fusion if you can get it to work in fusion. I use both of them and always switch back and forth.
Message 7 of 9
DarthBane55
Ah so if you go back and forth between the 2, did you try this part in Fusion?  Just cause you said you were using Inventor, I thought it meant that you were programming this part in Inventor.  If you didn't try in Fusion maybe give it a shot.
Message 8 of 9
turbobug64
No I did not because turning in fusion and inventor is the same. I have yet to find any differences in turning since turning in fusion is so far behind the mill stuff.
Message 9 of 9
DarthBane55
I think you are wrong...  Inventor CAM has no updates for 3 years, the turning in Fusion is much, much further ahead than Inventor.  The only CAM updates that Inventor got in the past 3 years are to keep up with the Inventor version, but no improvements are in it, for 3 years.
