Screen Shot 2020-06-29 at 2.07.37 PM.pngI have a goal of being able to design slot patterns for my microphone grills using splines. I have already been successful generating tool paths from sketches based on sketch slots, extruded into the grill body.
I tried the same technique with some splines shapes and struck out so I went to a very simple experiment. I created a rectangle, extruded it. I sketched the top rectangle with the rectangle tool, the middle one with 4 straight spline lines and the bottom shape with the slot tool. Extruded each.
In Manufacturing, using the 2D Slot tool, it works as expected on the top rectangle and the bottom slot but it refuses to accept the center (spline-defined) rectangle. (I AM able to select it and it previews exactly the same as the other pockets.) But it says "Invalid Contours".
