setting up start position for chinese 6040 cnc with mach3
jasongtr
jasongtr
hi there, i have a chinese 6040 cnc router using mach 3, i have an issue where in CAM setting the WCS i cannot seem to get the machine to start wherei need it to, please bear with me as i am very new to this
the cnc i have does not have home switches but i can zero x y and z axis, then when i go to run the program in mach3 it will start in a different location (not far away but not where i thought from where i thought i had set the wcs info)
clearly until i can sort out the machine working precisely where i expect i cannot use it very well
thanks in advance
daniel_lyall
Heres something you need to do everytime you start mach3
Move the machine to a safe spot in X and Y (where you wont to change tools) and move the Z axis up to just shy of the top of trave and hit ref all home if you have not set an ports or pins for it, it wont move just homme in places.
Then when you have done that Zero to the work pieces what is your work Zero, homing is setting machine Zero
What you are seeing is the machine going to G54 or G28 what is somewhere in spaces, sinces you have not hommed the machine it will slowly get worse to the machine slams into you or something and breaks.Smiley Happy
Also it wont start on you WCS unless you Zero the machine and set the program to start there, It will start from your G54 or G28 then move to the first cut position then when it's finished it will go back to the G28 position or G54, it's all in the Mach3 Manual what you can get from here, http://www.machsupport.com/help-learning/product-manuals/
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
jasongtr
fantastic, thats really helped
its all so confusing when you first start out, when setting up initially i was told to set the home position to a tick even though it doesnt have home switches (i may well install them at some point)
so now i know what WCS setup to use it really was very simple by taking those ticks off
really grateful for the advice, thank you
Respected citizens i have the same problem as the spindle doesnot start from where i want it to.... i could not understand the solution.. can u guys please explain it to me so that i could solve the problem... thank you very much...
daniel_lyall
What is written above is what you have to do everytime you restart the machine?
Home it, so it knows where Machine zero/home is
load the Gcode
Zero to the material being cut what is the WCS you set in Fusion, what gives you your work zero.
lift the Z axis up a little bit
Press cycle start, press cycle start again depending on tool change settings.
other than this there are 10000+ videos on youtube.
Daniel Lyall
The Big Boss
Mach3 User
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
