I have a DSP B18 controller and it is not easy to find the right postprocessor, particulary for 4 Axis. ( in my case along Y > C axis on the Driver but maybe A axis in postcontroller)
I think a part of the problem come from the different Factory who use this handler, they make some different Setup about wat must the DSP ignore other accept some particularity of the Gcode. But it is possible maybe to make an best setup for Fusion?
here are the Gcode otion Menu of the DSP B18
My factory Gcode configuration is fast the same as wat is in blue in the green picture, except spindle option.
Wat could I change for the DSP accept the generic 4 axis postprocessor ?
Now the postprocessor for 3Axis witch give me best result is the " AXIOM autopro Richauto A11 " except the function Read Speed , Read Feed does not work (eighter I tryed with this technique https://www.youtube.com/watch?v=yG1QERG4e9I&t=177s )
Thanks to share your Gocde setup at the AXIOM and LAGUNA and of course all the other Users of DSP controller
Bye
Francois
here is the code that DSP understand
François Moreau
bénévole sur le programme F360:
