Radius Mill - Feature Request
HarrisonClassic
HarrisonClassic
It would be nice to add a parameter to the Radius Mill tool to allow for a tool to be crested in the library that comes to a point.
Obviously, I created this one using the form mill - but a simple paramter added to the normal radius mill would make it more simple.
The only tool that seems to be able to be created does not allow for the bottom to be a point.
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
engineguy
@HarrisonClassic
Do you mean like the image below ? Seems to work reasonably well here ?
HarrisonClassic
Thanks Rob,
I get it now, although I cannot enter "0" for shaft diameter like you have in your screenshot. I thought that might have been the way to do it but it would not accept "0" - it does however allow for a small number "0.01" as per below which is more than fine enough for my application.
David Harrison
engineguy
@HarrisonClassic
What is the actual measured size of the tool that you have ?
FYI, to get a 0 value use 7 digits which seems to be the parameter used in Fusion so entering 0.0000001 will cause the value to go to 0 in that box, apologies, I thought that I had put that info in my post 🙂
HarrisonClassic
it comes to a point - so no width, but take your advice on the 7 digits, ta
David Harrison
