question on DXF files
im not sure where to put the bend line ill attach the file
daniel_lyall
Why do you need the bend lines for, creating a flat pattern is what does it for you in fusion automatically.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
HughesTooling
You need to use Flat Pattern not unfold.
Your file's attached, just enable the flat pattern in the browser.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks for that. but now i want to export it as a DXF and there is an option for that but i want to project the rest of the geometry but it wont do both the flat pattern and the projected sketch at the same time
HughesTooling
I don't understand, what else do you want to export? When I use Export DXF from the flat pattern workspace and open in Rhino I get this, what else do you need?
Mark
Mark Hughes
