prototrak slx lathe post
morgantooldie
Message 1 of 33
morgantooldie
Anyone have a prototrak lathe post they can send me? Need one bad
Replies (32)
Message 21 of 33
morgantooldie
Attached is post I use for my 2013 Prototrak 1630 SLX. VERIFY AND TRACK PROGRAM!!! USE AT YOUR OWN RISK!!!parameters 1.pngparameters 2.png
Message 22 of 33
Hello, Trying to cut a part on a ProtoTrak SLX. Has a few radius and will not cut part to how fusion shows it. Have tried all the post in here and can't get it to run proper. If anyone has any other information I'd really appreciate it! Also before I run part a message comes up "Mill to mill compensation Failed" and I have to click through a hundred or so and then runs. Thank you!
Wyatt
Message 23 of 33
Trigg3r
Hey @Anonymous, is it possible to upload your design or attach it here so we can take a look?
Export and save to your computer as .F3d and then attach it to a post here.
Cheers.
Message 24 of 33
Trigg3r
Also, unchecking Spun Profile in the setup will solve the Mill to Mill tool compensation error.
Message 25 of 33
I just bought a prototrak lathe.  Can you upload the post?
Message 26 of 33
morgantooldie
I have attached the post that works for my 2013 Prototrak 1630SX. Use at your own risk and trak/verify all programs.
Message 27 of 33
morgantooldie
It is also important to know...
When setting up your tools in the prototrak lathe. Lets use a DNMG332 as our example tool and it will be tool number 1.
Set it as a right hand turning tool in the prototrak control. Than touch x and z axis off as normal and enter the values. For the tool radius, use a value of zero.
Model the correct tool in fusion and it will do the tool nose radius comp in the software.
When posting, Reverse g02 & G03 should say yes. Any more questions I'll be happy to help
Message 28 of 33
THANK YOU! I receive the lathe in a couple weeks. I'll post the results here.
Message 29 of 33
I’m not sure why my lathe won’t cut a radius properly. Does everything perfect except for that. Anyone know?
Message 30 of 33
morgantooldie
Upload f3d file. Did you put tool radius as 0 in potortrak control when you set your tool up
Message 31 of 33
morgantooldie
  1. What’s not right about it?
  2. is reverse g2/g3 checked in post settings
Message 32 of 33
I saw to try that, I will run it in next 20 mines and see if that fixes it
Message 33 of 33
Cómo podría usar prototrak slx con mastercam te lo agradecería muchísimo
