Probing cycle - Probe WCS (Haas postprocessor bug)
piotr.2.mazur
piotr.2.mazur
I found a serious bug in generating the Probe WCS for the Haas-VF5 machine (I attach the postprocessor file).
The problem concerns the WCS number that the probe updates - if it is a number with zero at the end, the postprocessor truncates the zero. e.g. when G154.40 is set, the .nc file is G154.4
Fortunately, the machine was stopped in time before a costly collision occurred.
boopathi.sivakumar
Hi @piotr.2.mazur
Thanks for reporting this. I have made a ticket and will be fixed soon.
Boopathi Sivakumar
Principal Technology Consultant
Tomek.G
Hi @piotr.2.mazur,
Please check if changing the format to not trim will help.
It return S1.00 for G54 but i hope it should be OK
line 464
var probeWCSFormat = createFormat({decimals:2, forceDecimal:true, trim:false});
Tomek.G
Sr. Technical Consultant
piotr.2.mazur
I checked - it works fine, it looks like the right solution, thanks a lot Tomek.G
Tomek.G
Thanks for your feedback @piotr.2.mazur,
It's already fixed in library post.  Feel free to download and test the latest version.
Tomek.G
