Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Post processor
davismark5255
Post processor
davismark5255
With the latest update any new part i do will not post. Get error page when posting in lathe.
Replies (7)
jeff.pek
What error do you see?
  Jeff
davismark5255
Boopathi_Sivakumar
seems like you have problem with the post processor could you share your model and for what machine you are going  use this codes and the post processor details.
thanks,
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
davismark5255
Just trying to face turn the part and then post it to see the "g-codes".
Using post for FANUC TURNING / fanuc turning.
Problem started when i updated to the latest update. 2.0.4854
Anything done in to older update will post with no problem.
The newest update has select machine in setup, that maybe the new updated ver. problem.
None of the lathe post processor works now.
Boopathi_Sivakumar
Hey @davismark5255
I don't see any problem with my system it works fine for me .
I am also using the same version 2.0.4854
did you edit any thing in the post configuration ?
Are you using the installed post library ? or any other?
if you are using the same post configuration from installed library then try with redownload the .cps from the cam lib
here is the link Cam Post Library
This is my screen image of my post output
Cheers,
Boopathi
Boopathi Sivakumar
www.usamcadsoft.in
jeff.pek
For the moment, you need to remove the machine. Or create a new setup without one, and move the operations there.
Jeff
davismark5255
I had to turn off Cam Machine Configurations and Manufacture Workspace - Additive Machines
in the Preferences to try preview Functionality. Now I can post my lathe part. Why is there a problem with this and is anybody working on this solution?
