Onefinity CNC Machine - does it exist?
bbland808
bbland808
I'm very new to the world of CNC routers and the software needed to run them.  That said I am considering the purchase of a Onefinity CNC machine and plan to run it initially with Fusion 360 (personal use version).  The problem I'm having is I can't seem to find all the required elements. There is a Onefinity post processor available but I can't find the machine listed to select on the very first drop down menu under MANUFACTURE / MILLING / Setup / New Setup.  Is it common practice just to select the Autodesk Generic 3-axis as a substitute?
Replies (10)
boopathi.sivakumar
@bbland808
For 3 axis you can skip the machine selection. You don't need to select the machine.
But it will be handy to define the homing position values, and other stuffs line kinematic definition if it is a multiaxis machine. You can use Autodesk Generic 3-axis milling machine that will be a good place to start
Boopathi Sivakumar
Senior Technology Consultant
bbland808
Thank you for clarifying.  One the Onefinity forum it seems that most of the Fusion 360 users are reporting rather poor results regarding accuracy issues.  I was wondering if Machine selection had anything to do with it.
will_1
Hi @bbland808 ,
I believe the issue is with arcs. Are you seeing any arcs in your nc code? The most recent post from the download page should not be outputting any arcs. You could give that one a try and see if it resolves your issues.
Will
bbland808
Will, is your reply for this post?  I haven't gotten into any post processing concerns yet.
will_1
Hi @bbland808 ,
It was brought to my attention recently that Onefinity would handle linear moves better than arcs so updated the post to output linear moves instead. I guess I am not really understanding what you mean by "accuracy".
Will
bbland808
Oh OK, I'll keep that in mind when I get that far.  Right now I'm just trying to set everything up correctly inside the MANUFACTURE section to run the simulation and create the post process file.  I haven't actually bought the Onefinity CNC router yet...I'm just focused on trying to learn the software side for now.  It just seemed odd to me that there is a Onefinity Post Processor available but you can't select the machine on the very first menu selection.  My plan is to create a test file and send it to a Fusion 360 / Onefinity user to run for me to see how it comes out.  So anyone who fits the bill and is looking to make a couple bucks, please reply😎.
Butch
johnswetz1982
There is only one post processor because you do NOT need to pick a machine to put out code like the original reply already said. There is not a post processor per machine model type of deal.
bbland808
Thanks John for your response.  I'm new at this so bear with me while a further clarify.  So if Onefinity had more than one model and they had different post processors for them, would I then need to select the Machine to match the post processor?  Sorry I come from the office printer world where you had to have the specific print driver matched to the specific printer make & model otherwise you got strange output from the printer -lol.
So the answer to my original question of whether a Onefinity CNC machine exits within Fusion 360, the answer is NO.
Got it!
Butch
johnswetz1982
Generally no, The machine does not matter only the controller that processes the code. An example is Haas machines. They have about 20 different models of lathes and mills but can use 2 post processers for almost any machine, a Pre next Gen for older controls and a newer post for Next Gen controllers. The do have post for specific machines but that is just to tailor them to machine specific features.
A lesser common example is something like a post for a Siemens controller which is used and implemented by many different machine builders in different ways and those posts usually need a little customizing. But for what you are after there is probably one post that will run everything that your machines company makes.
bbland808
Thanks John, now I understand how this works.  Thanks for patiently explaining it to me.
Butch
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
