Need help with project/include for creating geometry for soft jaws
adventuremetal
adventuremetal
I'm stuck on figuring out how to project the geometry of the attached part for  machining the soft jaws to remove the carrier material and do the second op of drilling and tapping.  I'm set up with the carve smart jaws so I'm planning on holding the first op with mittee bite talon holders then machining aluminum soft jaws for the second op. Any help would be appreciated
Roger
ToddHarris7556
Personally, I would approach it like this -
  1. Create soft jaw bodies.
  2. Project side profiles onto soft jaw faces.
  3. Draw (3) circles tangent to the part profile for dowel pins.
  4. Use dowel pins to position part.
  5. Preserve soft jaw faces for another day.
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
adventuremetal
Thank you for the reply, that's a lot easier, faster and slicker.  What function did you use to project from the profile?
Roger
ToddHarris7556
There's no harm, of course, in milling full 3D soft jaws, but the their main advantage holding curved surfaces. You've got nice flat sides to clamp onto, so the only challenge is positioning against that bottom slant. You can, of course, use bigger pins if you feel you need them. They only need to project out far enough to catch the centerline of your part.
Lots of ways to get the sketch geometry - one quick approach attached.
Todd
adventuremetal
Thanks, Todd. I really appreciate you taking the time to walk me thru the process, makes perfect sense.
Roger
ToddHarris7556
Not a problem and glad it helped. Reach out anytime.
Todd
accountingFLKP6
As someone who is new to Fusion 360 but is proficient in Mastercam, I find this video extremely helpful.
