Hi, I was trying to set up a custom machine with the new machine builder.
I did manage to set it up with the machine builder, but when I try it in the simulation i get the no capability machine simulation.
What am I doing wrong?
Let me know, thank you.
Bye
Solved by GeorgeRoberts. Go to Solution.
Hi @ale.enneacca,
The reason for the error message is because your post doesn't support machine simulation, the functionality would need to be added in order to get this to work.
Good afternoon,
If you are only using a 3 axis machine, you can change the following line in your post processor:
capabilities = CAPABILITY_MILLING;
To this:
capabilities = CAPABILITY_MILLING | CAPABILITY_MACHINE_SIMULATION;
George Roberts
Manufacturing Product managerGreat George, it works!
I know it's useless for a 3 axis but it's nice to see the simulation of your own cnc.
Thanks again mate.
Bye
It's useless for a Minimill like mine, but it's still nice to be able to view the final result 🙂
a debt of gratitude is in order for the data George! presently I need to make a propper model of my TIG Welder Machine.
