Hello to all you guys,
I'm new around here and have been reading this post which I have found very helpful. I have been working with self built CNC router as a hobbyist for quite a number of years. I am currently fitting a co2 laser on my second build and while slowly progressing on the physical work, at the same time am doing research on how to cross over from design to manufacture. Since I am using UCCNC drives, from my search results so far, it seems that photo engraving is out of reach to be done on a CNC setup such as mine. Although it would be nice to have that option, it doesn't really bother me as I am mainly interested in cutting. The below is my CNC setup:
Design software: Aspire and highly considering Fusion 360.
CAM software: Mach3, (may consider to switch to UCCNC if no solution is found for laser).
CNC driver system: CNCDrive servo drives +UC300ETH-5LPT Ethernet motion controller, capable of having 2 dedicated PWM outputs - 1 for the router and the other for the laser.
Laser power: 150W
Working volume: X 2020mm x Y 1015mm x Z 400mm.
I am sorry for writing so much, but mainly I wanted to say thank you for the great help, patience and support, in understanding this issue.
Regards
Marten
