Message 1 of 15
In the situation below the 18mm cutter has a much longer Lead-In distance than the 8mm cutter.
Problem is, the 18mm is a bit too close the vice, which means I'm going to have to use the 8mm.
Is there are way of adjusting the lead-in/lead-out distances - I tried changing the radius but it didn't make much difference?
(Same 2D adaptive toolpath in both cases)
