How does this work guys? Turning it on makes no difference in the graphic. In my mind, it should be rotating the insert so the holder becomes axial not radial.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Have you tried changing the Type on the holder tab to Face Turning? You can also turn on the Round shank as well. I have attached a generic threading tool that will work for ID threads. The numbers are probable mot even close to being correct but you should be able to see how to get one setup this way.
