Message 1 of 8
Hello friends!!
Well, I'm performing a machining configuration as you can see in the image below.
In the fixation option
(Fixture)
I informed Fusion 360 that the Cylinder is a fastener, but when I run an Adaptive Clearing process, it still continues to create a material removal route, disregarding the cylinder as a fastener and making inappropriate collisions for the execution of this process.
someone could give me a support to work around this conflict in the execution of this route.
Thanks for your attention!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
