Announcements
External turning with internal tools
vilts
vilts
If and how can I do external turning with internal tools? I could use my internal grooving tool to do external grooves as well, but can't seem to find a way to program it in Fusion.
For internal turning spindle is turning CW, for external it should be in CCW and tool should approach from the other side. But if I change the tool to be as CCW tool, its direction changes to wrong.
It is slantbed lathe, so tools are "coming in" from the backside of the part, X- towards the part. With internal tools I could do turning from front of the part, when spindle is CCW.
Any ideas?
Replies (7)
johnswetz1982
You would need to create a copy of the tool, Reverse the spindle direction and change the direction to be appropriate in the setup/orientation tab of the tool definition.
vilts
I tried and it doesn't work. Tool still approaches from the same X- direction towards X+ and when tool is CCW, it is wrongly modelled as well.
Tool "model" should stay the same as is in CW  version, but approach should be from X+ to X- direction. That parts I can't get to work. If it is even possible.
You can check the model I attached to first post. There I have both CW and CCW tools.
Things are possible in real life that CAM software is not built for because it is rare and unconventional way to do things.
If using same tool to run internal and external groove, you CAN program it in Fusion but you will have to do additional G-code edit.
You can set right hand ID grooving bar for ID grooving running with CW spindle direction,  duplicate it, give it different number and change its setup to run with CCW spindle rotation.
In that configuration tool will cut outside groove with CCW spindle direction, shown with insert pointing up, as shown in model attached, from positive direction, now you mirror X axis, G2, G3 and I moves within that tool path (if using I and K for arc center).
This will make tool approach part from negative side of center line and work towards positive side or X0.
This makes single tool set as ID grooving bar on upper turret work as both internal and external tool providing you have enough X axis stroke to go to negative side of X0 and do outside work.
The key here is to mirror X axis of external tool path after generating tool path.
You cannot display ID tool outside of part and on negative end of X0 in Fusion, not meant to work that way so you get error but that doesn't mean you can't program it, simply change sign for all X (and I) coordinate, reverse G2 and G3 moves and you are in business.
vilts
Thanks! Yes, handcoding is always an option. Just wanted to be sure that if there really isn't a way to do this in CAM. Now I know 🙂
There is a way to produce negative X coordinates in Fusion but I never needed it so I am not sure what needs to be set.
Here is link to program I use to mirror Z axis on mill turn running sub spindle in same orientation as main spindle.
https://www.cnc-syntax-editor.com/download.htm
ddufford
I also have this issue.  I have a gang tool lathe and need to make a tool in Fusion 360 to represent my cutoff tool mounted on the top(rear) of the tool bar.  This cutoff will approach the work from the "rear" and run the spindle CCW.
Has anyone figured out how to do this in Fusion yet?  I know how to edit to mirror the X values in the .nc file, but it sure would be nice to simply generate the correct tool path in Fusion 360.
There is nothing there to figure out, concept has been around for a long time, use Fanuc generic turning post and see my example to set tools on front side of centerline, grooving tool and turning tool for back side.
I don't know what tools you are using so the way they are oriented in holder (insert pointing up or down) needs to be followed with correct spindle rotation in tool setup page.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
