Dotted text
Dotted text
arlimbad222
Dotted text
arlimbad222
hey all.
today i am trying to make a doted text on fusion 360 for machining I download some fonts and add to windows but somehow the dots are not circular and I cant use drilling on fusion 360. I attach some screenshot here help me if possible.
dsouzasujay
Hi @arlimbad222 ,
When we explode the Dotted font and select one of the sketch.
Now we can clearly see the reason for not perfect hole, It's created with 8 Splines but not with a single Circle.
Basically the font is causing problem.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
arlimbad222
hi @dsouzasujay
yes I know that is a font problem but I almost try 10 different fonts and the result is the same. so can anyone please suggest to me a font that makes a complete circle for fusion360?
and yes thank you for the quick response.
arlimbad222
Hey @dsouzasujay
I also try to make a manual pattern on path command and it also does not work for me like when I emboss all the circle fusion automatically cuts the circle and I can not select that particular circles in the manufacturing workspace kindly suggest me some tricks to do that dotted front drilling.
