Change Default Post Processor Folder
luke37QMQ
luke37QMQ
Is it possible to change the default folder for post processors? We have many posts that we have customized specific to our applications and we store them on a server so that all of our users have access to the most current release of the posts. (We also use HSMWorks in Solidworks, which has a different set of default library locations)
We'd like to change the default location so that when a user clicks Setup->Use Personal (or Installed) Post Library, that it takes them to our location on the server. Currently, users just make sure the current folder is our networked post folder which works fine, but we're looking for ways to reduce the chances of someone ending up with the wrong post. Has anyone had any luck with changing the default folder path? Thanks-
ChristopherMarion
Hi @luke37QMQ
Put all of your posts into your Assets folder.  Anyone that is working in your team would then be able to access the posts via the cloud.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
