CAM Bug - Trace - Cant change direction on an arc
benchwerx
benchwerx
I have been using Trace to create optimized facing paths for quite a while. In the last update this no longer works. I have tried it on both a OS X, and Windows. Can someone else verify? see videos for details.
Replies (12)
LibertyMachine
It doesn't work for me either. But, I never used it before, so I can't say if anything has changed.
You say optimized facing paths. Couldn't you use 2D contour and achieve the same results by setting the comp to OFF, lead in and outs also to off, tangential extension little more than half your cutter. That would get you what you want, unless of course you are doing something far out of the ordinary
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
benchwerx
The below image illustrates how I use it. There are multiple parts on a pallet. I create a path and use trace to face the entire batch. the tool doesn't lift or go out of order like some other operations do. I can also create multiple passes by duplicating and changing the stock to leave. It allows me greater control over tool paths without extra motion like tool lifts between parts. Let me know if you need additional info, and I can record a screencast of how I use it.
undefined
innovatenate
Autodesk Support
Autodesk Support
Thanks everyone for reporting this issue. I note report ID CAM-4501 has been created to track this issue. If at all possible, could you share the designs in this forum thread? These will be helpful to add to the report.
Thanks in advance!
Nathan Chandler
Principal Specialist
al.whatmough
@LibertyMachine is correct.  In this case, since there is not change in Z.  2D contour with compensation set to off should work for you.
In the meantime, we will look into this issue.
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
benchwerx
Al,
I tried using 2D contour and it has the same issue. The curve is currently not in the actual machining path, so I can work around it for now using a 45 deg angle to connect instead of an arc. I do have some work to do in the next few week that will require the use of an arc. I hope it is an easy fix. I also don't know what other operations might require the use of selecting a line. I expect that feature is broken across the board.
Here is a shared design: http://a360.co/29HMOO5
We note the same issue upon last update.  This bug has caused several headaches, (i.e. troubleshooting and lost production), using 2D contour is not a fix for us.  Please provide a fix or method to rollback the most immediate update (2.0.2204).
al.whatmough
This is high on Dev list.
That said, to be honest, a lot of the dev team is on summer vacation.
So, that is impacting how fast we turn around the update.
AL Whatmough
LibertyMachine
Summer Vacation!?!?! How dare they! Smiley Very Happy
Seth Madore
Tianq
Hi benchwerx,
When you select an sketch arc, it by default is set as a closed contour. Try to re-select that arc and change its style as an open contour, then the direction can be changed.
Can you try if it works for you?
Dave
Dave (Qing) Tian
benchwerx
eatureTianq,
That seems to work as a temporary workaround. Thanks. It took me a minute a minute to work it out. For those of you that use this feature, see the attached screen shot.undefined
Steinwerks
Alt+left click will also select one segment of a chain at a time.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
This solution worked for us, you are a hero Tianq!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
