I've noticed a few areas when Fusion will not produce a toolpath (sometime just a good toolpath), milling and turning if you have a minus stock. I should report these but usually need to get the job done and after the added wasted time trying to get a toolpath just haven't got the time!
Here an example, file attached. I can create a good finish toolpath but fails as soon as I enter a stock of -0.075mm. The good toolpath that's displayed is before changing the setting.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
@HughesTooling I'll make a ticket. Thanks for taking the time to post this issue.
@akash.kamoolkar I've run into these sort of problems with milling when you have touch avoid surfaces selected. It seems like the touch\avoid surfaces need the same offset as you've set for stock allowance, but you're not able to set negative clearances. Sorry don't have an example I can share at the moment.
Mark Hughes
@HughesTooling I've asked someone from the milling side to respond to your question.
