I've been using the parallel type path to machine a form in 2 steps: a roughing routine with 3mm stepovers and 5mm max stepdowns; and a finishing routine with 1 mm stepovers. Final cut depth is 23mm. When roughing, I've noticed that this path type causes the tool to hover in the air mostly for the first 2/3 passes, clipping just the edges of the shape until it engages more on subsequent passes. This is OK, but a bit of a waste of cycle time. Is there a way to adjust this -or- a better roughing strategy/path type I can use with the same ball end cutter (I don't have auto tool change)?
