5-Axis Trim Path
5-Axis Trim Path
pyramid.adam
5-Axis Trim Path
pyramid.adam
Hi there,
I've recently started using Fusion and am finding it really great, well done!
Hope you guys will be able to help with question, I want to create a 5 axis trim path for this part.
The part is going to be a vacuum formed part that is trimmed afterwards by a 5 axis machine.
I'm basically not sure which process to use to be able to create this, I'm at a bit of a loose end!
The photos I've attached show what the part itself (after trimming) and also just the line to make it easier for you guys to see.
If you need the .f3d please let me know.
Andy
DarthBane55
I think what you are after is "swarf".  But if you share the file maybe we can give it a shot.
pyramid.adam
Yes that has worked a treat, thank you!
