In this example I have a shallow pocket in round stock that has a bored hole removing material from the center of the pocket. I have roughed the pocket with 2D adaptive (please advise on how to make this more efficient since the path does not seem to regard the hole in the center). I then try and use 2D contour to finish the edges and bottom of the pocket and I cannot seem to get the path to clear the entire bottom face and the outside walls (only the outside walls and adjacent pocket face). The smaller cylindrical holes that partially break thru the ID feature are to be produced later in the machine sequence.
Any thoughts are appreciated
