2d Contour not selecting
Hi Team,
I try to select a 2d contour but it will not select it. I have other contours I can select within the same design but there is one I can not select and I don't know why. I have a video attached that shows that I can select other designs but the Munchie I can not select the whole lot. Please any suggestions.
meletis.stathis
Hi @Anonymous,
It might be a problematic open contour that is produced from the extrusion of that particular font that generates this issue. Could you please post the file so we can take a look at it?
Meletis
Meletis Stathis
CAM Software developer
@Anonymous I have attached the file. I do that all the time and never hat any problems with that. I also try to enter the svg file again and do the same thing but still not working. The svg file is attached as well.
Thank you for your help
meletis.stathis
Thanks for the files. I took a quick look and I could reproduce the problem that you've seen. I could not find anything distinctly wrong with the SVG or the extrusion.
Hence, I've opened ticket CAM-23998 for further investigation.
Meletis Stathis
seth.madore
Sometimes the selection presents too many options. That typically solves as an odd closed section, but this time it decides it wants a single segment. That bit is curious...
Seth Madore
I have created a different svg with the same writing and font and it worked perfectly. Have a look at the video. Even if the problem is solved it would be interesting why it don't work with the first svg file.
