I found an acceptable way to import OpenSCAD files into a fully editable Fusion360 body and I thought I would share in case it can help someone else.
I often come across files on thingiverse and elsewhere with OpenSCAD files, but I could not figure out a good way to import these files into Fusion360 while maintaining the proper shapes and dimensions without dealing with a mesh.
When I use an imported STL (mesh converted to Brep) the faces are not continuous and I cannot adjust tolerances with the press-pull function
Failed press-pull on continuous face from SCAD>STL File conversion
When I convert from SCAD to CSG in OpenSCAD, then from CSG to STEP in FreeCAD (as per the workflow above) the continuous face is easily adjusted with the press-pull function
Successful press-pull on continuous face from SCAD>CSG>STEP File conversion
