Print View - images not working in Modern UI
philipfrench
philipfrench
This example below used to work in Classic and Modern.
However, now it is not working in Modern.
What is the correct / official way to refer to an image field to render in a Print View?
The issue seems to be that Modern uses a different base url to classic... COMBINED WITH... the Print View source editor is removing any initial "/" when I save.
The effect is that I want to save a source url like this:
src="/servlets/ImageServlet/?imageid=${item.itemDetails.sections["Advanced Print View"].fields.CUSTOMER_LOGO_FILE_ID.value}
But the editor is stripping (removing) the initial "/". So "/servlets" becomes "servlets".
In classic this is not a problem, because the Print View is launched in not-relative way.
In Modern, it does not work, because the links seem to be relative to a deeper URL.
Result - I cannot enter a URL that downloads either /servlets/ImageServlet, or /api/v3/xxx or /api/v2/xxx, because the leading "/" is removed by the APV editor.
Even if I used the "insert artefact" option, to generate the table, this gives me a suggested link eg:
${item.itemDetails.sections["Image Details"].fields.IMAGE_CLOSEOUT.value}
Well, that just gives me the integer number of the field, certainly not a picture.
Does anyone know how to get image links working in Modern? Thanks.
This is currently blocking migration to Modern UI.
catot
Phil,
I got this working on our tenant:
<!--<img src="/servlets/ImageServlet/?imageid=${item.itemDetails.sections[&quot;Diagram Test&quot;].fields.VERTICAL_SECTION_1_IMAGE.value}" alt="" Width ="100"/> -->
I don't have any explanation why that works, but I remember I struggled with this a while back. Hope that helps.
philipfrench
Thanks Cato
the problem is that when I enter this text,
/servlets/
gets changed to
servlets/
i.e. the first "/" is removed when I save it. This seems to be some "security" thing.
The problem then, is that when run without the "/" in Modern it does not work.
Do you have this example working in Modern?
I think it may work, but if you edit-save in the APV definition, it will change "/servlets" to "servlet".
If you have pictures working in Modern, I would be very interested to do a screen share and see how it is working for you.
thanks
phil
catot
I tried copying my source code over to a new APV, and for me that works the same as before. Also editing and saving on that new APV again does not alter the "/" in front of the servlets string.
We're using Modern.
Let me know if you would still like a screen share.
catot
Here's an simple new APV that I set up to test on a different WS:
<div><!--<img src="/servlets/ImageServlet/?imageid=${item.itemDetails.sections[&quot;MySectionName&quot;].fields.MyImage.value}" alt=""/> --></div>
 This works for me.
philipfrench
I actually just found a way to stop it from removing the leading "/" on "/servlets", which is what Modern needs.
In the picture, you can see the img tag starts with "<" in the normal way.
However, if you remove this single "<" character with "&lt;" (without quotes) then the parsing of the tags is apparently confused, and the leading "/" does not get removed when you save.
Then it works (pictures display in Modern correctly).
Thanks to Cato and others that contacted me via email.
replace like this:
