When you create a sheet metal body, where you close an item so they just touch, the ends fuse instead of staying separate. That does not really make sense when modelling with sheet metal. For solids it would. I know the workaround is to just a bit of tolerance, but it should not be necessary.
Has been logged with development team as: FUS-40600 but would be interesting to hear other good ideas for same improvement.
Also it would be nice if a flange could "shape" automatically after the other parts of a sheet metal it meet just like two flanges made at the same time next to each other does
best
Hoegge
