Import 3D dxf
Import 3D dxf
Please add support for importing 3D dxf. Not just 2D.
3 Comments
HughesTooling
You can import 3d DXF\DWG file using the data panel in Fusion. In a project just click the upload button then select your file.
mark
rezabek.blaz
I tried this but its import, just three lines. SW imported this file with 30 splines.
HughesTooling
Well that is a bug and you should post an example in the support forum so AutoDesk can fix it.
Mark
