Springload simulation in models
I would like to be able to design a mechanism to be spring loaded..
I have tested rest position and to drag away the component behind another component having them on contact set. I was thinking I could get the first component to stay behind the second and dont be able to get back to its rest position until I remove the second component..
If there is another way to do What im trying to do I haven't found it.. It would be rally helpful to test mechanisms.
Here is a test model I did to test the above.. I can drag the piston down under the pin and as long as I dont releas the mous button I cant get it back up, But I would like it to stay untill I remove the pin. Not when releasing the mouse button.
http://a360.co/2l2w225
Thx
2 Comments
This would be awesome
More generally, a rigid / soft-body simulation engine would be fantastic and doubly so if you threw in the ability to simulate sensors, actuators, and an API to plug those into external control software
et.teljemo
@roambotics_scott
Great input!!.. that would be really nice to have this kind of features available in the model workspace or in another dedicated funktion simulation workspace.
