While F360 is lacking proper part configuration management and configuration/design tables, I found a way around to achieve similar results and avoid copying same file with different parameters.
I call it parametric configurations, or in-place configurations and it works pretty well, except it quickly becomes unmanageable.
First, what I do.
I create, say, a parametric part model. Taking rod as example, it has 3 parameters: length, diameter, and chamfer size. So I enter 3 user parameters in the Parameters window, like this:
Then I save this model with default parameters. Whenever I want this part to be used in another model I insert it in the design, break the link (it's necessary, otherwise it's not possible to change parameters), and adjust settings of the rod as I want. One of interesting features is that it's possible to replace, say, Length parameter with some other parameter, which already exists in the model, and which will become a driver for the Length of the Rod. For example, it can be offset value of a joint, so the Rod will adjust its length depending on how far joint components are from each other, like shown below:
With this setup the Rod length will be automatically adjusted depending on the joint offset you specify in the model, like shown below:
You can add as many rods as you like from that very same file and configure them individually and independently of each other:
It's all great and very powerful (you can design your part once and configure in many different ways in the same or many other designs), except for for a few things, and a number of limitations to be called a proper configuration management. The most limiting one is this:
As you can see, every Rod adds its set of parameters directly on the top level of user parameters. Even three components, three parameters each makes it pretty clashed. Imagine a dozen of parts driven by 7-12 parameters..Yet another problem I noticed, when you delete component you previously inserted and conlgured, its parmeters remain in the list of user parameters. As you can see it can quickly become a mess, especially that it's hard to tell, after a number of insertions and deletions, which parameter belongs to which exact part in your design.
I can think of a few things to improve parameters management (which can also be used in configuration management (coming soon as far as I understand)):
