Show only
Search instead for
THERE IS A FREQUENT MISCONCEPTION BETWEEN "SPIRAL" AND "HELIX". THE IMAGE SHOWS A HELICAL PATTERN, AN YES, IT WOULD BE A JOY TO HAVE SUCH FUNCTIONALITY WITHIN FUSION.
Hi Kevin, The "Spiral Pattern" was not my idea originally. I merely pointed out that the model displayed was indeed a "Helical Pattern". Please search for "Uhlhorn" who is the author of the original post. adeshjunkie
MoI3d includes a 'Vertical Step' option to the circular pattern tool which would get the results you want, Maybe Autodesk could add both the vertical and Radial steps options
I also have this problem. Trying to cut holes in tube and later place items in those holes in a spiral/helical pattern as part of a vertical garden project.
I chose to redraw the CAD for my vertical garden (originally done in OpenSCAD) in Fusion 360 as it was reasonably simple and help me learn to use Fusion 360. I obviously chose the wrong thing to draw in Fusion 360 as it seems like it isn't possible (at least not parameterised in the same way).
I have found a lot of posts/comments on this missing feature on the web, youtube and these forums. None of the work-around solutions are particularly palatable though.
A cut-down example of the OpenSCAD I was trying to reproduce looks like:
// Lets also place some cylinders in the holes (later replaced with pot planter objects) for (i = [0:holes]) { this_hole_offset = i * tube_hole_spacing; this_hole_angle = (i * tube_hole_angle) % 360;
