Chamfer in Sketching
Hi
As subject, can we please have chamfer tool available in the sketch environment
Matt
5 Comments
Paul010206
Observer
I agree this would be very usefulle to me, Please add
Yes please. A chamfer option in the sketch environment would be very useful
Bump. Make it an "either or" with the fillet tool in sketch mode. Right click to select which one or attach your preferred in the tool bar.
Ps- Not having this makes me feel like I am the idiot and forgot where it was.
voller
I just ran into a situation where I could us the chamfer in a sketch, as it becomes a radial pattern with other shapes of which 3D is extruded from, into 2 separate components. There is a workaround of doing the pattern once it is 3D, but then also requires more steps to produce the same shape as several components have to be made to do cutting and joining of the final shape. Whereas how I'd do it in other packages, I could extrude once for each component.
Kinda odd, as chamfer is one of the simplest shape commands found in every 3D/CAD package I've ever used. This is one of those commands that should have been in from the start. Please add it in! 🙂
jcpieterse888
Please add this. A chamfer call out in the 2 D sheet environment will also be appreciated.
