Zoom to "Real Size"
Zoom to "Real Size"
A zoom feature that lets you view at "to scale" size. This allows for more intuitive feel of the model you're creating, especially when you're working with smaller files.
9 Comments
zodiaceng
This would be sweet, but Fusion would need to know your monitor specs/etc for it to be at all accurate. Too many times I zoom with a scale up against the screen to get stuff close, or print it out 1:1 on paper. Would be nice if this was an option for sure.
huszak.marcell
I gave you an upvote because the idea is cool, but it's really hard to make. There's option for that with pdf docs, and in archicad i think but as much as I seen those, they worked awkardly bad 😞 But I hope it happens one day.
samyyboyy
I too would use this!
It wouldn't be a terrible solution to have the user physically measure their screen and enter the dimensions into a first-run setup dialog, per device. Then Fusion would only need to additionally know its own window size within the screen.
snecx
It will not be difficult as it only needs a one-time calibration. Rhino for example supports Zoom 1:1 and the setup actually asks the user to measure the width of a specific bar on the calibration screen. It is one of my most frequently used function so I hope this gets implemented in Fusion someday.
campbellblc
Another vote for an on-screen scale, I keep digital calipers on my computer desk, but that only serves once as a verification, because as soon as I re-scale, it's gone without a trace.
A one time "THIS IS IT" input for my screens would be perfectly acceptable. Say a "1:1" symbol in the top header bar.
Thank you.
jakubkr
The best option:
1) Enter display size ... x inches (is on every box)
2) Enter display aspect ratio (or it could be done automatically, that info should be seen by fusion to scale properly)
3) Use a known object (10cm bar, credit card, A4/A5 paper) to fine tune
Shouldn't be too difficult and it will be really useful. Getting sense of scale for small 3D printed objects would save me from perfecting sub 1 mm things no one will see anyway.
johnanger
Fusion could show a 10cm or 3" ruler on the screen with a zoom button. Then the users puts a physical ruler on the screen and zooms in / out till it matches the on screen ruler. The user then presses the "Rules Match Button" and it is calibrated 1:1.
sergio_righi
Observer
In Siemens NX, you can calibrate the screen. It shows an on-screen scale that can be used to calibrate the screen. Just an idea.
Lazurx
Observer
Hello. Was there any feedback from Autodesk about this functionality? I'm very much interested.
