Currently there is no direct visible relationship betwen the joint constraint e.g. Rigid and the joint origins involved in the joint.
When looking at a specific joint origin of a component it is not clear if it is involved in a joint constraint. It would be reallynice to see the the realionships to all joint constrint a particular joint origin is involved in.
Similarly a joint constraint can be selected and then right-click edit joint can be selected but this only shows ow many components have been selected(component 1, component 2) but;
- This does not list the name of that component. One would have to select the component in the edit joint UI to get visual feedback which components are involved.
- One component can have multiple joint orgins. It is not clear which ones are involved in the current joint constraint.
It would be helpful when debugging a faulty joint constraint sitation when these bidirectional relationships can be seen in the UI.
