Variable Feed/Speeds for 2D/3D Adaptive
I love the adaptive tool path. It's fantastic. One issue I have occasionally is with large pockets. A lot of the time we will pre-drill a thru-hole in the part for an end mill to plunge into, then adaptive the pocket out. This has proven faster at times then helical lead-ins. The issue comes in at the first 10-20% of the pocket. At HSM Feeds/Speeds, there isn't always enough room to get the chips out when moving that fast.
It would be fantastic if I could set the speed to start slow and increase over time. Like start at  "Speed A" until 30% into the pocket, then switch to "Speed B". Or make it a gradual ramp to "Speed B".
I can go in and manually change the G-Code, and we have had to do that at times. But seems like this would be a nice feature to have.
