user Paramaters in text...
In a sketch you can not use the value of parameters or  calculated values in text feilds.
It would be nice to be able to show these...
That way one could put an info box in the sketch that shows you how it is currently set up.
4 Comments
When Sketching it would be convenient to be able to defined user variables when creating the sketch. Currently User Parameters have to be defined before the sketch is started.  If parameterS are not defined before entering sketch the sketch has to be stopped and the MODIFY/ CHANGE PARAMETERS windows opened. I find that creating parameters comes to mind when I am creating the sketch.
j-tucker
Observer
Yes please.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
