Update outdated drawings with updated title block
I have done roughly 1000 drawings for various parts using a title block that i created in fusion since the new editable title block option has become available. I have been using a template to create my drawings. Today, the title block information had to be updated and all previous drawings now must use this newly updated title block. I cannot seem to find a way to update all my previous drawings with the new title block without having to re-draw each part again. In the future i may need to add new information to the title block if my business transitions again. Is there something i am missing here as i believe this is something that really needs to be available if it isn't already, the idea of using an exported version of a title block to edit outside of fusion and then to import into each drawing is a very long winded solution to this problem. All that needs to be done is: Make the drawing templates (that are created in fusion) work the same way as when the user is prompted to update a drawing after modifying the model for said drawing. This way, when i edit my drawing template inside of fusion, when i open a drawing that used the outdated template, i am prompted to update to the latest version of my drawing template, that way i am always using the same drawing template for ALL of my drawings and not just the future ones. I feel that this would be a very useful option, as the idea of going through thousands of drawings and redrawing them all is extremely unappealing.
Thank you for your consideration.
2 Comments
HughesTooling
Someone just asked similar question in the support forum. I came up with a workaround that might help a bit where you import a temple containing a title block with the same name as the tile block in the existing drawing.
See this link.
Mark
Indeed!
HughesTooling workaround isn't that complicated, but I would still like this to be a bit more straight forward.
Also, the attributes get reset, which is a shame.
