It would be very useful if Fusion 360 would be able to determine Lult, the ultimate design load of a component. This value is essential to performing lifetime fatigue studies using rainflow counting techniques and most often it's value is unknown. A description of it can be found in MLife, a program from the National Renewable Energy Lab (NREL) at https://nwtc.nrel.gov/system/files/MLife_Theory.pdf. If possible, Lult would be determined by Fusion 360 either from a force along an axis or a moment about an axis of the part. The advantage in knowing Lult is that simulated lifetime fatigue studies can use Lult to determine the expected lifetime of a part, or conversely so that parts can be designed with a desired lifetime based upon knowing the simulated lifetime loads on the part.
