Trim surface should also work like split body
It would be nice if I could just trim a body with a surface without having to explode the body so I can do a patch on patch trim task!
3 Comments
colin.smith
Status changed to: 実装済み
Hi @cekuhnen
What is the desired result?  You can currently split the body with a surface.  You can trim the surface with the body.
What am I missing?  Do you want to punch a hole through the surface with the cylinder?
cekuhnen
Ops that screenshot is wrong.
Split body splits a solid into two new solids.
I would have to delete one side
then unstitch the solid
delete then internal trimmed end cap
Stitch stuff back together ...
so it would be nice if the Trim command could just do that at once trim the other area of the solid away and provide an open surface
compare the timeline
colin.smith
Adding to advanced modeling list
