Trim/Split TS faces with sketches
It would be really handty to be able to split  or trim T-Spline faces using sketch geometry. I'm not sure if that would be possible or not but it would seem like it would make the workflow alot easier.
4 Comments
cekuhnen
To do this you have to use the design timeline where you can sketch the TS model, exit the mode let it convert to Brep and trim the result with a sketch.
TS being poly based cannot technically be trimmed.
deyop
There is research underway to provide T-Spline trimming with options for graphically trimming similar to trimmed NURBS and re-evaluated boundaries and when the work is ready I am sure we will want to include it. For now Claas is right that conversion to BRep is the patch to defining a boundary.
Title says it all, I want to be able to trim a t-spline plane with a sketch.
Tags (2)
colin.smith
Status changed to: Gathering Support
Trimming T-Splines is in the backlog for the T-Splines dev team.  It is a fairly large project.  Release date TBD.
