Trim or extend lines produced with circular pattern
I would like to know why equally spaced lines produced via sketch "circular pattern", in my case 8 equally spaced around 360 degrees, cannot be trimmed or extended.
5 Comments
HughesTooling
Patterns in Fusion are parametric so modification to an item in the pattern will modify all copies and modifiers like trim, extend and break are disabled. You can modify sizes with dimensions or dragging though. To make the items independent just select the pattern icon and delete.
Mark
PS This question should have been in the design section not on the ideastation.
gordonclamp
Hi Mark, thank you for the solution
Regards Gordon
Sent from my iPad
gordonclamp
Hi Mark
The solution you suggested re deleting the pattern icon, where is the pattern icon?Circular pattern.png
gordonclamp
Hi Mark, Sorry, found it,
Thanks for your help Gordon
keqingsong
Status changed to: RUG-jp審査通過
